code p0449
Old 10-08-2009, 10:17 PM
  #51
454SuperSport's Avatar
P0443 is for the purge valve circuit, the valve behind the throttle body. check the "PCM 1" fuse under the hood first. unplug the valve and check the pink wire for voltage with the ignition on. also check the pins in the connector and make sure there not bent. didn't you just replace it not too long ago?
Old 10-09-2009, 11:29 AM
  #52
PT's Slowest Truck
budhayes3's Avatar
Crap, that changes everything, he said it was a small leak code, I believe that the purge valve has been replaced. I'd also inspect the connector and make sure that the wires aren't backed out of it since it was un-plugged to replace the purge valve.
Old 10-09-2009, 07:44 PM
  #53
Go5.3tt06's Avatar
Hey man. I did check also. They are good. The purge valve is new about 2 weeks ago been replaced.
Old 10-09-2009, 08:14 PM
  #54
You still got the old one? swap them out and see if it works.
Old 10-10-2009, 09:57 AM
  #55
Go5.3tt06's Avatar
Yes still have it. I will try. But been 2 days no light back on so far.
Old 10-10-2009, 03:25 PM
  #56
PT's Slowest Truck
budhayes3's Avatar
I'd still check the wires going to the purge solenoid just to make sure that there isn't a wire that's half in and half out of the connector, giving you an intermittent problem, only takes a second to look Funny how you got a code for the purge valve circuit after the purge valve was replaced.
Old 10-11-2009, 11:21 AM
  #57
Go5.3tt06's Avatar
This morning the engine light come back on. I getting really tired of this and get me pissed off. Cuz I been paid from what shop do the inspection for.
The code SHOW is P0442
EVAPORATIVE EMISSION SYSTEM LEAK DETECTED (SMALL LEAK)
Tell me where it cause and why they do that? I really want to get all off the code. I been check everything it look so good nothing damage. I dont know what is come from.
Old 10-11-2009, 12:06 PM
  #58
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by go5.3tt06
this morning the engine light come back on. I getting really tired of this and get me pissed off. Cuz i been paid from what shop do the inspection for.
The code show is p0442
evaporative emission system leak detected (small leak)
tell me where it cause and why they do that? I really want to get all off the code. I been check everything it look so good nothing damage. I dont know what is come from.
unfortunately, if you can't see anything physically, and everything is tight, it probably requires test equipment such as a mild air pump, scan tool, and possibly a smoke machine (don't try pumping compressed air into your gas tank or you will blow out the pressure sensor on top of the gas tank and be dropping the tank to replace one of those).
Old 10-11-2009, 05:35 PM
  #59
Go5.3tt06's Avatar
Lets see what I been doing today. Want you see careful what I been had done. I already replace new purge valve, new design with Evap Vent Valve Cansitors with small filter box. Run with some 5/8 heater hoses too. I test all electric connect the wires. They are good connect. I did use ligh tester with alll of wires and fuse box too. Itis all good. I dont know why the engine light come back say Code P0442. I might fedd up and take to bitch dealership let them do it.
Old 10-11-2009, 10:28 PM
  #60
those hose clamps on the new vent valve look loose also check the little green screw-on cap above the throttle body
Quick Reply: code p0449
