Codes 171 and 174
Codes 171 and 174
Every year when it gets cold outside my truck kicks error codes 171 and 174 for right and left banks lean. What do I do to fix this problem. I'm guessing either a tune or injectors. Any one know what to do? It is for a 2000 Silverado with 5.3, Custom cold air with the screen removed on the MAF, Hypertech, and straight exhaust with factory y pipe.
PT's Slowest Truck
Off the top of my head, I'd say that either the intake is warped and leaking, which could be affected more by the cold weather, or it could be false readings from the MAF which will also throw system lean codes. You could try cleaning or swapping the MAF (if you have a friend with the same truck and/or part number MAF), and spraying around the intake with carb cleaner while observing the idle to check for leaks. If that all checks out, I'd be checking fuel pressure, and viewing the vehicle data with a scan tool or tuning software...
