Coil Ground Wire- What color is it and Where?
Does anyone know what color the ground wire is for the drivers side coils? Also where does the ground connect to?
I've concluded that I have a bad ground feeding my drivers side coils. (At least I assume the Megafuse IGN A provides to the drivers side where I've had most of my problems.) Unlike mine, I checked my brothers truck and there is no voltage on that fuse.
Any info would be greatly appreciated.
The IGN A fuse is not related to ignition system operation.
All 8 of the coils are powered by the IGN 1 circuit/relay. Odd cylinders through the INJ 1 fuse and even through the INJ 2 fuse(Pink wires). All 8 share a common ground circuit(BLK wires). Each coil has its own trigger circuit from the PCM. Each bank has a separate low reference circuit from the PCM (brown wire)- even cylinders are connected to pin 61 on the green PCM connector- the wire is Brown/white at this point. Odd cylinders are connected to pin 60- the wire is still brown.
muncie21
09-07-2015 09:55 PM
