Cold start rough idle and 1-2 shift is FIRM!
This is a 99 5.3 Z71
I am having rough idle issues on startup, once the truck warms up it idles fine. Also, the 1-2 shift will blast you sometimes. It's not every 1-2 shift but probably 50% of the time it is rough.
From what information I have gathered searching around on this site from people with the same issues it seems as though the intake / intake gaskets might be my culprit. So, can anyone verify this is most likely the problem?
Also, if I am going to pull the intake, is there another intake that it could be beneficial to do an intake swap while I have everything apart?
Any help is greatly appreciated!
High on diesel fumes
Originally Posted by v8
have you cleaned the throttle body, maf? had the injectors cleaned?
I probably need to add that this only happens on the first start of the day. After my initial drive to work it runs and idles fine the rest of the day. So, that leads me to believe that once it gets colder this problem is only going to get worse.
Mossyoakglock
07-17-2015 08:30 AM
GreyChevy
07-07-2015 08:57 PM
