collector question..
12 Second Club
I have some pacesetter LT's and I have them clamped to the 3inch pipe..
seems that the clamps are leaking, and I need to find a diffrent way to seal them up..
my question is..
is anybody using a donut gasket setup, and if so how do they hold up???
I have seen a few other setups, and would like some info on others as well...
anybody?
my question is..
anybody?
I know I've seen V-bands before, but I can't find them now. You have a picture? Do they clamp over the two pipes when they butt together? What kind are you using Thunder? People talk about not sealing with clamps, but I don't know what syle clamp they are using, if they are talking about slipping the exhaust over the header collector and clamping that (like moregrip below) or just mating the two pipes and clamping like you show it.
Andrew
Andrew
Granted this isnt the collector connections... But i've had problems after initial installation of my Corsa exhaust with the clamps leaking before the muffler. Sure it didnt effect anything except excess noise.
But, taking everything apart, coating both sides of the connection with some Ultra-Copper RTV Sealant, and then reclaming everything sealed it up well. Infact when i installed my ASM Long Tubes last month, i didnt even screw around with the chance of leaking and used the RTV on the collector gasket and flange.
12 Second Club
deerpark muffler has some clamps that look nice. they put some on my truck and its holding up so far. they are the kind like in the picture above
they are leaking like a mother...
look like the ones above, but with 2 bolts instead of one.
might try the RTV tho...
I assume you used high temp RTV....
