COMP 216/220 .525/.532 114lsa in 4.8
Old 12-29-2006 | 08:57 AM
onebadrubi's Avatar
a 3000 stall will barely even be noticed in your truck. I would go with a 3000 and the bigger of the two cam choices. That and with 4.10's will still be able to pull stock pulling capacity and be able to spin the tires off the line.
Old 12-29-2006 | 03:28 PM
OKslow's Avatar
That is what I was thinking/hoping-onebadrubi, but don't want to have all that work in it and not turn out the way I want.
ap2002, what motor did you have that 212/218 in and what did it sound like at idle?
Do yall know if the pacesetter longtubes and off road y pipe from texas speed will bolt in place of the factory stuff?
Thanks again for all the help
Old 12-29-2006 | 11:37 PM
SlvrSierra4.8's Avatar
What are the full specs of the 212/218 cam. Anybody have a link to it from the Comp website. Was trying to find it online but didnt have much luck... My 4.8 needs a cam too...
Old 12-30-2006 | 12:05 AM
navy_ao_05's Avatar
i have the same setup as you want i like the 216/220 in my truck but you def need a stall
i love this cam you should get it.... you have questions just ask me
and im planning on getting a 3200 stall
Old 01-01-2007 | 05:55 PM
brodystruck's Avatar
Originally Posted by OKslow
I guess thats a HD hood? It looks great, I am crazy about 67-72 trucks. Yours kinda makes me regret having a gmc. BTW-I am originally from Corpus-lived everywhere else since then. How do you like them 4.10 gears?
I am still wondering about the 216/220 cam because of what ap2002 said. For the motor to be where it's workin right I would need a 3200 stall converter, right? Does that mean it will be a turd until then with that cam? I was lookin for the "mild mannered driver" snake eater metioned. I do carry a four 4-wheeler in the bed sometimes and have had a ski boat behind the truck. I don't want to make it useless. Thanks for all the info.
Yah, it's a HD hood, I wish I would of done a complete HD front-end swap though... I like the 4.10 gears but I noticed a substantial fuel mileage drop when cruising above 75mph. Kinda makes hauling *** on the freeway a costly option... I got a four wheeler that goes in the bed quite often too, it should be just fine though...
Old 01-01-2007 | 05:56 PM
What are the specs on your truck?
Old 01-01-2007 | 10:02 PM
navy_ao_05's Avatar
specs? like cam specs? or hp and tq numbers?
Old 01-01-2007 | 11:19 PM
Phantom's Avatar
11 Second Club
Here is what the 21/218 .525 comp cam sounds like in a 4.8
212/218 comp in a 4.8
Old 01-02-2007 | 05:33 PM
Engine displacement, mods, etc...
Old 01-02-2007 | 07:09 PM
litreddevil's Avatar
Banned
that is the cam i ran for a few years you will need more stall i had a 3000 then a 3200 then a 3400 and it worked great with all of them and these were with 5.3s and 6.0s
it will be a great set up but if i were you i would get more stall
Quick Reply: COMP 216/220 .525/.532 114lsa in 4.8
