Comp Cam
Flyer, what cam is it that you have? the 212/218 high lift? I'm running the 02' LS-6(204/218) @.050" and .551/.547) and I thinking of doing a 5.7 or 6.0 this spring and summer. so I kind of shopping cams too.
did you lose any low-end? the ls-6 cam felt like it lost some to about 3k. I really need a converter the one in the burbs stall @ 1700 and will only flash to 1800-1900 rpm so its not very quick out of the hole. the ls-6 cam was put in w/ ls-6 timing chain and I 've heard they are 2 degrees retarded so its not helping low and mid.
I thinking maybe a custom cam w/ rpm lobes, 208-212 intake and 216-218 ex. w/ 115 LSA +2,3
Originally Posted by BigKID
Can't you get the 216/220 in the high lift XER lobes like the 212/218? That cam on a 114+2 is what I am looking at doing if I can get a set of heads.
Just a small cam (2k vette cam), new tranny, good bottle pressure and cool air. I am hoping for even better this comming sunday if everything goes well. Haveing some exhaust work done to fix a previous hack job on thursday.
btw.. let me know if you yank that 212/218 out. I may take it off your hands.
Hey man, what do you have your shift points set at? pm me and give a lil more info on how that cam is?
Originally Posted by RED2K
Them cam wil work fine but I would go with something with a bit more lift if I were to do it again. I lost quite a bit bottum end with it but since then have added a stall and gears. I have over 35k miles on this cam and the only issues I have is tuning ones. This cam needs a good tune for sure to get the gains it is designed for. IT isnt a monster by any means but big enough to need a tune
