Comp Cam 212-218 High Lift Installed
Old 04-14-2004, 10:33 PM
brent eb02's Avatar
thanks guys....
i have a new volant cai so that should be fine
it s not surgeing it just idles too low and then dies
the 01 denali has drive by wire i think
will it still has that screw on the TB???
I PLAN TO HAVE JULIO TUNE IT @ CARTEK ASAP
but until then ill try anything
thanks again
Old 04-14-2004, 10:35 PM
F8L Z71's Avatar
Ack,
Drive by wire doesn't have the set screw
If we can't come up with an answer check the www.Corvetteforum.com. They also have drive by wire and almost everyone there has a bigger cam than you and could give advice or just do a search. Great board with nice people.
Old 04-14-2004, 10:36 PM
F8L Z71's Avatar
LMAO, just noticed you own a modded Vette and are probably all over Corvetteforum. Hahaha
Old 04-15-2004, 12:55 AM
BigTex's Avatar
You'll probably need a small hole in the TB to allow more air at idle. Or just get your tune.
If its drive by wire on that Denali, then you'll find that it will learn the idle and throttle like a vette does. Just start it, let it idle for a few minutes. Put it in gear and hold brake and let it learn idle without giving it gas. Do the same thing with the A/C on and off. See if it runs better afterwards.
Old 04-15-2004, 03:58 PM
abbo7's Avatar
So, on the drive-by-wire, the PCM will learn and it will open the TB accordingly at idle??
Old 04-15-2004, 04:16 PM
BigTex's Avatar
Somewhat, yes. It will idle poorly immediately after starting, but after a few startup cycles and learning when it needs to do to get a good idle, it will run better. It will not run as well as it would if you had some professional tuning.
Old 04-15-2004, 05:05 PM
FILE's Avatar
Originally Posted by The_Mexican
What's up File?
6250 rpm first - second
6100 rpm second - third
and 5xxx something (don't really remember this one right now ) third - fourth
Sounds good. I am shifting at about the same rpm's as you are. I just can't really remember the 3-4 shift since it's not very important.
Old 04-15-2004, 05:33 PM
Flyer's Avatar
What's up File?
I got mine shifting something like this
6400 1-2
6500 2-3
6300 3-4
It still feels like it's short shifting.
Old 04-15-2004, 10:09 PM
brent eb02's Avatar
thanks guys
Old 04-16-2004, 01:53 PM
The_Mexican's Avatar
6400 1-2
6500 2-3
6300 3-4
I know what you mean Flyer, but since the only thing I have in the tranny is shift kit and servos and not a fully built one I don't wanna push it to much, I'm saving for a built tranny though .
ARC
57
02-21-2022 10:54 AM
low2001gmc
07-23-2015 05:10 PM
Ammadien
07-22-2015 08:50 PM
Offroadunleashed
07-20-2015 02:25 PM
projectnightcrawler
07-19-2015 11:30 PM
Quick Reply: Comp Cam 212-218 High Lift Installed
