Comp Cams LSR 265LR HR12 Cam?
Old 01-01-2010, 10:16 AM
NoShow's Avatar
The only problem with this is if you have high compression you might have trouble with knock. It would almost be better to have more duration to bleed off some pressure. But if you're staying under 10.1 or 10.2 it shouldn't be an issue.
I'm wishing I had gotten like a 220 or so because the knock issue requires precise tuning and it's a pain. But I wouldn't want to give up the low-end torque anyways. I have 10.5 comp
Old 01-02-2010, 10:24 AM
Brutal_LS1's Avatar
I plan on maintaining stock compression even if I decide to do a head swap later on.
JordanH
08-08-2015 07:59 PM
OLD BULL
08-01-2015 05:00 PM
low2001gmc
07-23-2015 05:10 PM
WICK3DxGATA
07-21-2015 06:59 PM
projectnightcrawler
07-19-2015 11:30 PM
Quick Reply: Comp Cams LSR 265LR HR12 Cam?
