Comp xr275hr
need .070" shorter pushrods to get .030" preload
when I tighten the rockers the valves open! I made sure the lobes were down. Good thing I didn't get pushrods before install. I did not measure base circle before install.
![Embarassed](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_emb.gif)
that a great cam, I wouldnt think about it twice, there are people running bigger cams than those and running mid 12's.... so you made a great choice... so what pushrods did you end up getting? the 7.400 should of worked perfect..
all buttoned and tuning
I still have stock injectors so nothing done in higher RPM. Actually it's still in the shed learning how to behave at idle. Put plates on tomorrow
