compression?
11 Second Club
compression?
so what would my compression be on a 6.0 block with ls-1 heads? is that going to push up to 10:1 or more? i am force feeding my motor. will i need to get different heads or get the chambers milled?
Re: compression?
The 5.7 heads will raise your compression and do not flow as good as the 6.0 aluminum heads. I would stay with the 6.0 heads if you have the aluminum ones. If not, try to find some. The lower compression will be better for you anyways.
zblee
11-11-2015 12:41 AM
