compression ratio
I'm sorry. I thought you were asking for a 5.3L motor compression. Didn't read the whole post thoroughly enough.
It will raise the compression ration to ~10.5-10.9:1 that I have seen, all depends on whether the heads have been worked or not.
And just an FYI, a set of milled LS6 heads will be right at the same CR as the 5.3's.
zblee
11-11-2015 12:41 AM
