computer relearn
Old 10-01-2004 | 03:59 PM
loco_silverado's Avatar
Default computer relearn
ive got a question for you guys,
does computer relearn help?
if so how do u do it?
and ive got hp tuning, do i need to have it
reprogrammed?
Old 10-01-2004 | 04:07 PM
RED2K's Avatar
you shouldnt have to reprogram it with a hp. you should be able to plug in , program , and go. To do a relearn unplug the battery and turn the key on to drain the power from the pcm. The truck will runing rough for a bit and want to stall at a stop for a while. It should straighten out with time and miles.
Old 10-01-2004 | 04:14 PM
do you think ill gain any power?
Old 10-01-2004 | 04:28 PM
RED2K's Avatar
i doubt it. What it is doing is trying to learn the base idle and the base throttle position. Once it learns this it tries to learn the new fuel trims and what not.
Old 10-01-2004 | 04:38 PM
RED2K's Avatar
edit.......
RustyD
05-23-2016 07:04 PM
Cammed4ever
09-30-2015 03:38 PM
StrokeTheLS
09-29-2015 08:33 PM
Velocity1
09-22-2015 01:32 PM
supershift67
09-18-2015 08:21 PM
Quick Reply: computer relearn
