Cooling issues with electric fans
I have truck in signature...full bolt on LQ9 with the stock 190 thermostat. My truck never used to get above 205 with my clutch fan. Now that I have the LS1 fans, my truck will run around 195 cruising, but if Im sitting in traffic on a hot day, the temps can shoot up to 225 pretty quickly. The fans are snug against my stock radiator and both fan motors are running hard but doesnt seem to be enough. It will cool down if I let it idle with the hood up after getting that hot. Does this mean I need a bigger radiator, I never heard of someone having issues with LS1 fans not keeping up and dont see how going to a cooler thermostat will help.
Baltimore Whore
Hmm I have your basic setup with FI, I have yet to have my temps get above, 205, sitting in the slop.. Are you sure that they are both running, turning freeley? How long has this been happening??
John
John
They are both running and turning freely. Its always ran this way since the installation, but sometimes now I get stuck in traffic so it has now become an issue I need to address.
I was doing a little searching and may have found something that might help, but something I didnt think was or is neccessary. I dont hardly ever run the AC in my truck, so I never bothered to hook the AC wire up that came with my fan harness. I read that when this wire gets juice,(+) it turns the fans on high. Does that mean they are always running at low speed if I dont have that hooked up? It overheats even without running the AC.
Im thinkin the same thing, I may just run that wire to a switch and run them on high without the AC or short it out in the harness somewhere so that when they come on, they are always on high via the computer. I know this should not be the solution, but this POS always gives me a hard way to go, fighting me the whole way. Maybe I got a lazy water pump, or need to change out the antifreeze and run more water in the mix..
