Cooling Problem
#24
Originally Posted by litreddevil
well did you fix the truck yet what did you fine
Well I have fopund it is a PEICE OF **** no not really but everything seems to be fine (visually) I am getting the new clutch tommrow and going to try that then I am going to take off the water pump and take a look at it the the Radiator and clean it up but I have checked all hoses and they were fine and its not leaking so I am just going to tear it all apart and start from the begining checking each part I will let you know how it turns out Tommmrow
#25
when i got my truck last year it was doing this exact same thing, the previous owner had also switched to green from orange... after some snooping around on here and reading about sludge i took the radiator out and had it rotted out. sure enough the guy said a good bit of it was plugged up. all was fine for the rest of that summer. until recently that is... but now i have it narrowed down to a bad fan clutch. anyway in summation id have it rotted out,its cheaper than a fan clutch. unless yours is completely sloppy like mine and an obvious problem. hope this helps
#26
#27
Well I am going to say that I am about 99.9% sure it is the fan clutch. Now I guess I pay 69.99 + tax for a clutch or do the E-FANS what do you think I should do I am still going to boil out the radiator and clean up they whole system but like I said the Clutch is the problem (I think) will see!
#28
carid
10-01-2015 10:22 AM
Wrecker 426
09-30-2015 10:39 PM
