Copper spray or not on stock MLS head gaskets
#22
thats another thing, the heads are new the block deck is all fresh, i dont think I need it. neither does Corey. just clean good.
#24
no second guessing bud....got this from cometic,
Why does Cometic recommend MLS gaskets to be installed dry?
Cometic Multi-Layer Steel (MLS) head gaskets go on dry because they are coated with a sealant. Each MLS head gasket is coated with a .001" thick viton rubber that is bonded to the outer stainless steel layers. Adding an additional sealer can hinder the performance of an MLS head gasket.
#26
#29
Those work excellent Corey! That's what I've been using for a long time for cleaning up gasket material, etc..... The great thing about them is they are easy on aluminum!
