Corvette or Billet Servo?
Corvette Servo VS. Billet servo. What do you guys think. with the corvette servo do you guys get a chirp between gears? This is going on after allen takes out 80% TM. And in the Overdrive servo worth it to buy, if i dont haul very often (maybe 1 or 2 times a year).
Thanks
Thanks
do corvette for the 1-2 servo and the billet for OD servos, also replace the accumulator piston becasue they are weak plastic.
http://www.kdsperformance.com/transhifkitw3.html
can be very harsh and jolting that's why people are oing the corvette on the 1-2 but not on the 3-4. their is alot of people who have tried different things so we shall see.
personally i recomend both billet servo's, but some say it's overkill. as for the accumulator piston. it can be done in the truck. takes about a minute or two to do once the pan is down.
I went with both billets and I think its a little too harsh. Sometimes it can get a little annoying but you learn to live with it. I also had Allen lower the psi below 50% but it didn't seem to make that big of a difference. I wouldn't mind trying the vette servo in the 1-2 spot but I will probably just leave it alone. I try and go for the best as I don't want to have to buy better after I have invested in something.
Thanks
Thanks
Thanks Jason.
If you want really nice firm 1-2 shift and be able to bark that shift at WOT then get a Transgo kit and the vette servo it will also make the other shift nice and firm as well that way if you get all the TM removed it will be a little better for your tranny than just having the servos!!!!!
