Couple of 370 q's?
Old 10-23-2007, 04:56 PM
ranwalk's Avatar
Originally Posted by Z06 DREAMING
what are your guys' opinions on stock crank and rods?
On a budget, nothing wrong with stock rods or crank. Stock crank can handle a TON of power. Unless you are building a stroker I wouldnt spend money on a crank. If money allows, upgrading rods would be the only thing to look at. Also, what power level are you looking at? 500-600rwhp on stock rods seems pretty common these day. Just gotta keep the tune right
Old 10-23-2007, 08:53 PM
BigKID's Avatar
Is this going to be a N/A, N2O or Boost motor? If it is a N/A motor I would not hesitate to use the LQ9 rods in a rebuild as long as it isn't going to be spun to 7K+. For a nitrous or boost motor, it all depends on the levels. As Randy said, the tune has to be right. Detonation and RPM is what kills rods in N/A motors. Crank is a no brainer. I used a new stock crank on my otherwise fully forged and studded 370 boost motor.
Old 10-23-2007, 09:09 PM
dirt track racer 81's Avatar
i think for 100-125 shot the lq9 rods would be just fine..my plan if i get the pistons and rods i listed i wouldnt be scared to do a 200-225 shot
Old 10-24-2007, 09:39 AM
ZR1 DREAMING's Avatar
It will see spray as stated in first post. Tune will not be an issue, as I have a great tuner.
My main concern here is will rods and a crank still hold their structural integrity after seeing relatively minor surface rust? Not looking to break any records with this... just be a solid runner for about a year with frequent track time on juice.
Old 10-24-2007, 10:06 AM
ranwalk's Avatar
For what you are wanting to do it will be fine
11 Second Truck Club
bluecajun5.3's Avatar
surface rust on the rods itself shouldn't cause a problem. clean them real well with scotch brite pad. now rust where the bearings go and where the piston pin goes, then they will need to be reconditioned.
Old 10-24-2007, 10:10 AM
Thanks Randy, I just wanted some positive reinforcement from y'all before I put money into a re-build.
Thanks Lance, I plan on cleaning them thoroughly. I just want to be sure the strength of them hasn't been comprimised.
AdaMax
05-16-2016 11:35 PM
lukn4trbl355
10-21-2015 11:19 PM
Infernohoe
48
10-02-2015 10:25 PM
The_W
10-01-2015 02:35 PM
old motorhead
09-29-2015 08:22 PM
Quick Reply: Couple of 370 q's?
