Crank Spacing - Vortec Motors
Old 07-21-2007 | 08:54 PM
Lord Aries's Avatar
Default Crank Spacing - Vortec Motors
Ok, gotta a fun one you smart guys...
Do all of the vortec Motors 5.3 LM7, 5.7 and 6.0 LQ9 share the same recessed spacing of the crank and flywheel/flexplate???
For example, to put a 4L80e on a 5.3L you can use the stock 6.0L Flexplate and spacer (like I did). I am wondering if i can use the Stock Clutch and Flywheel for a 1996-2000 HD truck with a 5.7L in my 2003 truck with a 5.3L... This is for my NV4500 manual trans swap project...
If i am not being clear on what I am asking let me know and i will try to rephrase the question(s)...
Old 07-21-2007 | 09:58 PM
kbracing96's Avatar
As far as I know there are all the same except for the 99 and maybe 2000 6l which have about a 1/4" longer crank tail.
Old 07-22-2007 | 03:12 AM
Keith's Avatar
That sounds about right. Those engines were paired up to the 4L80E and used the longer snout on the back. The newer engines when paired with a 4L80E or a transmission of the same TC mount to bellhousing flange offset would use the flexplate spacer.
Old 07-23-2007 | 11:00 AM
Lord Aries's Avatar
What about the LQ4 vs the LQ9? Is there any deifirence in the Crank spacing on them?
Old 07-23-2007 | 11:42 AM
SS_bnoon_SS's Avatar
The LQ9 was never offered with the 4L80E trans, so you shouldn't ever find one with the longer crank from the factory. The LQ4 was paired with the 4L80E in '99-'00 using the longer crank as stated above.
Old 07-23-2007 | 12:47 PM
Lord Aries's Avatar
OK so, if I have this right I should be able to take a Flywheel and clutch assembly off of say a 2003-2006 HD Truck with the LQ4 6.0 and bolt it right onto my LM7 5.3?
That’s what I did with my 4L80e, I used a Flexplate and crank spacer from a 2003 HD Truck that had the 4L80e in it…
Old 07-23-2007 | 02:00 PM
saphunt2r's Avatar
Question? I have 99 4.8, now will that have a short or long crank? I have a 02 LQ9 I going to drop in what is going to work for that? What combination am I going to need, TC and flexplate from my 99 4.8?
Old 07-23-2007 | 02:13 PM
kbracing96's Avatar
only 99-00 6l had a long crank Your 4.8 flex plate and TC should work fine.
Old 07-23-2007 | 03:55 PM
Lord Aries's Avatar
Sweet, thanks for the info guys! As usual you all kick azz!!!
Old 07-23-2007 | 10:09 PM
saphunt2r's Avatar
Thanks kbracing96 great! shes going in small cam, pipes and tune..
TXsilverado
11-26-2015 11:54 AM
black00chev
08-12-2015 02:56 PM
InsaneDomestics
07-27-2015 03:42 PM
jmarkway
07-18-2015 10:23 PM
4B11T
07-13-2015 04:48 PM
Quick Reply: Crank Spacing - Vortec Motors
