crazy ac doesn't work at idle?
Old 06-21-2005 | 11:37 PM
budhayes3's Avatar
PT's Slowest Truck
The ac will not cool if you don't have fresh air flowing across the condenser...you gotta make sure that you get at least 1 fan on high when the a/c compressor enguages. Once you start driving, the consenser gets good air flow, and that's why the a/c is fine on the move.
Old 06-21-2005 | 11:39 PM
white1's Avatar
Originally Posted by stall speed
Ok guys,I'll let in on the secret to ICE COLD AC with 05 fans.I have NELSON harness with 1 fan high AC on,2 fans low to temp,both fans on high, temp and AC.The trick to cold AC in traffic is use manaul switch to put both fans on high.My AC gets so cold in traffic I have to raise temp up 2 clicks.I live in LOUSIANA and temps here get up to 95* everyday Also I have a Yank 2600 converter.I tow a construction trailer in traffic,if I put manual switch on,trans temps never get above 155*.Moral to the story is get Nelson harness WITH manual overide switch and use in traffic to pull air acoss condensor at all times.
Where at in La? I'm in B.R.
Old 06-21-2005 | 11:47 PM
02sierraz71_5.3's Avatar
I dont have a fan shroud at the time and have the same problem as soon as I start moving ac is fine Bud is right
Is the polarity correct on the fans?
Old 06-22-2005 | 03:39 PM
6gear's Avatar
I have to say thanks guys because I have been having the same problem for the past year or so. I have my fans activated by the computer my question is how can I get the fans to come on with the a/c? Can I hook a manual switch into the same location of the blue 42 wire (I think) to the relay?
Old 06-22-2005 | 07:00 PM
multmigs's Avatar
this sounds really weird, how is the wiring any different from what is stock on a 05 truck... Bryan told me there is a way to patch the manual lead on his harness into something called the ac request line?? Anyone know what/where the hell that is???? Bueller???
Old 06-22-2005 | 08:49 PM
Tap into Pcm wire going to pin 42 which is ground for fans.Run a switch inside truck and back to engine bay and ground it to alternator bracket.Turn on switch in traffic and fans will run countionously and will go to high speed every time ac cycles on.
Old 06-22-2005 | 09:39 PM
6gear's Avatar
Thanks, I'll do it.
Old 06-23-2005 | 07:55 AM
multmigs's Avatar
This is exactly what I'm complaining about, who the hell wants this as a final setup, can you imagine me telling my wife she needs to do this after she cried about the real reason I was changing fans on my almost brand new truck to the tune of $600.. THe factory isn't doing this so whats the story???
Old 06-23-2005 | 08:13 AM
white1's Avatar
I went to pep bays and bought a temp controller. It has an a/c turn on wire for the relay. Wifey has no idea
chopperloco
07-10-2016 11:45 PM
shawn96gmc
05-17-2016 05:15 PM
Mossyoakglock
07-17-2015 09:30 AM
07NBSChevy
20
07-08-2015 08:27 PM
