Critique this 5.3 setup
Old 08-29-2006 | 08:50 PM
11 Bravo's Avatar
Default Critique this 5.3 setup
I am about to trade my Jeep in for a Silverado 4x4, 5.3, single cab stepside. It will be used off road, and for towing my car. It will be a dd. This is what I'm thinking on:
LT's, ported stock heads, 222/222, 3200 stall, bolt ons.
I have no idea what gears come with it. I'm currently looking at 3 different trucks, '03-'05. I want to keep good low end torque and it will be lifted with bigger wheels/tires. Don't know what size yet, it still needs to be able to tow a trailer. Of course I want a decent lope, but not too radical. Would this be a good, mildish all around daily driver setup?
Old 08-29-2006 | 09:43 PM
tarinitup's Avatar
9 Second Truck Club
you'll need a smaller stall for towing. Try a yank TT 2600 instead of the 3200 you have planned.
Old 08-29-2006 | 09:49 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
you need 2600 or lower stall and at the MOST 216 duration cam.
Old 08-29-2006 | 11:44 PM
onebadrubi's Avatar
yes I aggree you come down on the cam and stall size. You will be suprised. You can always spray a small 75-100 shot to pick up the HP you would have lost on the little bit bigger cam if your trying to also make some good track passes with it.
And most likely you will get 3.73 gear ratios.
mhorn0817
07-08-2017 02:54 AM
JordanH
08-08-2015 08:59 PM
vmaxpro
07-27-2015 11:45 PM
WICK3DxGATA
07-21-2015 07:59 PM
Choda
07-21-2015 04:47 PM
Quick Reply: Critique this 5.3 setup
