Curious about towing with a supercharger.
Old 01-10-2016 | 11:07 PM
  #21
BlackGMC's Avatar
Resident Retard
Mine does not heat soak that bad sitting in traffic idling in 100*+ texas summer heat with the AC on max. Iats about 30* above ambient. I used to daily drive mine everyday. Then again i do have a phenolic spacer maybe the bypass valve in the maggie helps. I could pull over and put my hand in the blower and it was warm and not burn my hand. I dunno just my experience. My old turbo setup was about the same.
Old 01-10-2016 | 11:21 PM
  #22
Vortec350ss's Avatar
I'm just referring back to GMCtrk's experience at the track this year. The numbers I saw were absurd...
Old 01-11-2016 | 12:06 AM
  #23
Dans 05's Avatar
Originally Posted by George C....
IAT at idle in traffic is hot with a blower...iats from turbo cant be high from not spinning compressor
Now with a metal intake youll have heat soak...cocaine for example heat soaks with IAT in intake by firewall
Example project blue lightning....turbo output for IAT was 250* IAT2 which is in intake is 100* after a full 1320 pull
So motor isnt seeing high iat like a PD blower
Same truck would see 198-220* with ice on a 1320 pass
Yes a turbo gets hot but still best route for towing otherwise factory vehicles would have PD blowers to tow
Id love to see a PD blower tow for 6hrs and 9000lbs
Open it up and see how bad the tolerances of case became
Wait i did see a PD blower that was used for towing...blower was in desperate need of rebuild...this was from towing a camper
I have a mp112 on a stock 6.0 in an 05 1500 with 80e and a 2600 stall I pull a 30ft travel trailer I have no issues yet going on two years I don't beat on it hard but it will make 9 lbs if you lean on it hard longest pull was to Kansas
Old 01-11-2016 | 12:10 AM
  #24
Dans 05's Avatar
Originally Posted by shupe
I've been towing with my tvs for the last few years. Only regret is I didn't do it sooner.
How many lbs of boost are you running
Old 01-11-2016 | 09:58 PM
  #25
shupe's Avatar
7-8 lbs of boost max. Fully loaded camper and truck bed puts in me around 7k.
Despite the hills in the Ozarks I haven't been in a position to need to run much more than a few lbs of boost. Even the steepest grades combined with the parachute like drag from the camper do I see the gauge hit 2-3, any more throttle and I'm accelerating up the grade which pointless.
Old 01-26-2016 | 12:48 PM
  #26
applebmw's Avatar
Default Supercharger
Shupe...SO, I am looking at Magnuson Supercharger, for my 11 Avalanche, 5.3, just for towing the camper in the mountains. What your saying makes good sense in my head, I only want to stay at given speed up the hill, say 55mph, not race to the top, anything is going to make heat if your hammering on it. In your opinion everything would work fine? Stock exhaust, CAI, and blower....This truck geared from factory to pull over 8,000 lbs. I maybe pulling 7,000 at the most.
2002_Z28_Six_Speed
01-05-2016 01:06 PM
Rick Predmore
11
12-28-2015 10:12 AM
thumper67
12-24-2015 11:28 PM
lsxperformance
12-22-2015 11:32 PM
YAMAHAGUY
12-16-2015 06:53 PM
