Custom Cam/ Heads and Nos installed....
Old 04-30-2011, 11:41 PM
Bigschwerm's Avatar
Default Custom Cam/ Heads and Nos installed....
Installed a Custom grind Comp XER 222/222 .563/.563 114lsa along with a Ls6 oil pump and ls2 timing set with comp lifters and comp pushrods. this replaced my old Custom grind 216/224 110 lsa
A set of 862 Heads Milled .030" Ported and Polished along with 2" Intake Valves installed with Ls6 Springs.
Waiting on the NOS kit I bought from bluecajun5.3 in the classifieds...going to run a 150 shot....
Just need to run some logs and send them to my tuner to dial in the new cam and heads and get a tune for the 150 shot at the track. This should hold me over until I decide what route I want to take with my 6.0 build... First impression of this cam: Pulls Hard!
More info to follow....
Old 05-01-2011, 12:46 AM
BadAssChevy327's Avatar
nicee. hows the comp lifters are they loud? my buddy has a set sounds like a sewing machine, most likely a pushrod length issue though.
Old 05-01-2011, 01:10 AM
dmelvin's Avatar
You planning on hitting the dyno?
I just got the heads I bought from you installed like 2 weeks ago.
Sounds like you're going to have a monster of a 5.3 on your hands.
Old 05-02-2011, 08:43 PM
Bigschwerm's Avatar
Lifters were loud for about 5 minutes but now they are quiet as can be.
Old 05-02-2011, 08:46 PM
Bigschwerm's Avatar
Dyno is in the works hopefully in a few weeks. I love this new cam! Pulls extremely hard even on the old tune...and didn't notice much of a low end loss at all. Extremely happy with the swap!
How do you like your setup?
Old 05-02-2011, 10:06 PM
Pollo432's Avatar
This is exactly what i want to do to mine. What size stall are you running??
Old 05-14-2011, 09:23 AM
Bigschwerm's Avatar
I am currently running a 2600 I6 TB Stall......I did however upgrade my gears to 4:10 over the 3:42's which made a huge difference. My shift extensions still suck but i have my eye on a 3200 stall.
Old 05-14-2011, 10:20 AM
dmelvin's Avatar
Love it... more power everywhere and gained 2-3 MPG on the interstate .
With the cam and heads, even before the tune, I heard the words "scary fast" from one of my friends from about 3500RPM up. When you're the only one in the 45 mile radius that has a H/C setup let alone the only one that has it in a pickup, you're gonna raise a few eyebrows.
I think a dry shot and stall may be in the works soon though
5.3Okasai
03-09-2022 01:07 PM
BennyB
08-01-2015 08:48 AM
Ketis
07-23-2015 12:37 PM
4B11T
07-13-2015 03:48 PM
Quick Reply: Custom Cam/ Heads and Nos installed....
