cutout wiring
cutout wiring
i have a cutout one of my friends gave me that i want to wire myself instead of spending 60 or 70 bucks on just the wire and switch...
but im not sure how i should go about wiring it up myself, how should i do it and what should i use?
here's a picture of the connector thats on it right now and the wire
you need to order the rest of the wiring from whatever company that is qtp? badlanze? it will have the other connector with a switch added to it. if you do it this way it will be more secure be cause they are a twist and lock setup , umm you might be able to cut that end off and strip the wires and run your own but it would be way simpler the frst way.
Wrecker 426
09-30-2015 09:39 PM
