Cylinder Head info
Cylinder Head info
This info was originally posted by Ruff Boy on RGV Trucks
241 & 853
Heads: 1997+LS1 5.7- liter passenger car
Material: Aluminum
Part Number: 12559853 (1997-98)
1255853 (1999-00)
12564241 (2001-03)
Combustion chamber Volume:66.67cc
Compression Ratio:10.1:1
Intake port Volume:200cc
Exhaust Port Volume:70cc
Intake valve Diameter:2.00-inches
Exhaust valve Diameter:1.55-inches
What you need to know:
The standard issue LS1 heads is best all-around head for the street / strip engines . A thorough porting and millimg job plus a valve upgrade on these will really wake up your engine.The heads have undergone only minor revisions since their introduction in 1997 , most notably a switch from perimeter to center valvcover bolt configuration for the 1999 model year. Each style has its own dedicated valvecovers and coilpacks mounting apparatus.
243
Heads: 2001+ LS6 5.7 liter passenger car
Material:Aluminum
Part Number: 12564243
Combustion chamber Volume:64.45cc
Compression Ratio:10.5:1
Intake port Volume:210cc
Exhaust Port Volume:75cc
The LS6 cylinder heads is essentially a tuned-up version of the LS1 head. At 65cc, the combustion chamber is slightly smaller and more efficient than the LS1. The more efficient design shortens burn times and ultimately means less ignition timing advance is required to produce the same power. And because less timing allows more efficient combustion, the Ls6 heads allow the engine to produce more torque. The exhaust port is a unique D-shape that improves flow. LS6 heads are the best choice only when all-out power is needed. Be prepared for a big price tag at the dealer or steep core charge from your head porter.
706 & 852 & 862
Head: 1999+ LR4 4.8-liter Truck
1999+ LM4 / LM7 5.3-liter Truck
Material:Aluminum
Part Number: 12559852, 12561706 ,12559862
Combustion chamber Volume:61.15cc
Compression Ratio:9.5:1
Intake valve Diameter:1.89-inches
What you need to know: These small combustion chamber truck heads offer no advantage over an LS1 head except the smaller combustion chamber. This along with milling of the deck surface will allow a slightly higher compression ratio to be achieved. Because of the smaller intake valve installed in these heads a valve upgrade is practically mandatory.
873
Head: 1999-2000 LQ4 6.0-liter Truck
Material: Cast Iron
Part Number: 12567873
Combustion chamber Volume:71.06cc
What you need to know: The LQ4 heads are found on the low-performance version of the 6.0-liter truck engine. They offer a large combustion chamber that lowers compression ratio making them perfect for a forced induction application. Swapping on the LQ4 head drops the compression ratio of a typical LS1 engine to 9.:5.1 Cast-iron casting are heavy!
317
Head: 2001+ LQ4 6.0-liter Truck
Material:Aluminum
Part Number: 12562317
Compression Ratio:9.4:1
What you need to know: The LQ4 head received aluminum heads starting in models year 2001. All other features are the same as previous years iron heads. This is the workhorse head for street / strip turbo and blower cars.
035
Head: 2002+ LQ9 6.0-liter Truck
Material:Aluminum
Part Number: 12572035
Compression Ratio:10:1
The LQ9 heads are found on the high-performance version of the 6.0-liter truck engine and debuted in th Cadillac Escalade for 2001. This heads is virtually identical to the LS6 head, with the same improved intake and exhaust ports, but like the LQ4 head, it has a larger 72cc combustion chamber. This is the head of choice for max-effort forced induction engines
241 & 853
Material: Aluminum
1255853 (1999-00)
12564241 (2001-03)
243
Material:Aluminum
706 & 852 & 862
Material:Aluminum
873
Material: Cast Iron
317
Material:Aluminum
035
Material:Aluminum
gtyler04
07-28-2015 06:21 PM
sauldgold
07-23-2015 02:15 PM
