Cylinder Head Water Vapor Lines
Old 06-27-2010 | 09:34 PM
Mrgoodwrench3's Avatar
Originally Posted by Preston129
What did you do on the line that T's off the passenger head and goes to the rad? Did you just add an AN socket to the stock rubber hose? Or replace the whole thing with the same hose you used for the crossover piece?
I used all new hose. Coming off the passenger side head the hose connects the radiator side tank.
Old 06-27-2010 | 10:54 PM
Wilde Racing's Avatar
How do I change this text
That was SO last year..... (or three ago)
lol
Looks good.....
Old 06-27-2010 | 11:19 PM
tarinitup's Avatar
9 Second Truck Club
what do those adapters go for. Might be a good mod for when I bored and have extra cash.
Old 06-27-2010 | 11:45 PM
Spoolin's Avatar
GFYS and STFU
Pretty cool!! I likey!
Old 06-28-2010 | 04:53 AM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
This is what I did. It's the LS Water Vapor System.
Made by kurt urban performance
Old 06-28-2010 | 09:37 AM
Preston129's Avatar
$9.95 for one, or ~36 for 4. I'll split the 4 pack if someone wants to go in on it.
Old 06-29-2010 | 02:19 PM
2001CamaroGuy's Avatar
Looks good. I made my own adapter. I started with the factory pieces, cut the tubes off, then high-temp silver-soldered steel 4AN fittings onto them and had then chromed. End result is the same but I don't have to deal with an extra fitting to leak.
Old 06-30-2010 | 01:26 AM
If you guys really want to step it up there is a ton of meat in the head to drill and tap.... The pic below features 1/8 NPT vent ports.
Kurt at W2W was the first to mention this little tip (about 8 years ago) although none that I know of has really tested the theory fully....
Old 06-30-2010 | 01:37 AM
Any benefit? I would think once the head is purged of air, the vents are pretty much useless.
Old 06-30-2010 | 09:43 AM
Read this thread.
Quick Reply: Cylinder Head Water Vapor Lines
