Damned VSC
Old 04-23-2004, 04:20 PM
You should have used 10ga to begin with. With the current draw reaching 20+ amps at start up, that is a lot of current to pull over 12 ga or smaller wire.
Old 04-23-2004, 04:56 PM
LOW2000's Avatar
I wonder if any of the tuners like mike would be willing to just turn on the fan control using their software for a minimal fee.
Old 04-23-2004, 05:07 PM
bigguy75inches's Avatar
my just went out,, but i think its cuz i held a powerwasher with soap to it to clean my engine compartment. i called flexalite, and emailed them a webpage for proof i got it less than a year ago, and they sent me one no questions asked. should be here this week
Old 04-23-2004, 05:11 PM
I love the ram air setup on that intercooler!
oops! wrong post! sorry guys! that one was meant for that sr 10 vs hyundia
Old 04-23-2004, 05:22 PM
NovaTime's Avatar
i really think a Microcontroller is the way to go. I'm willing to write the source code for it, if you want it to turn on based on varying temperatures.
Old 04-23-2004, 05:29 PM
99Silver6.0's Avatar
You can wire the fans to your PCM and let it control them. FarmTruc is making harnesses just for that setup. Thats the route im gonna try.
Old 04-23-2004, 05:39 PM
NovaTime's Avatar
I'm going to try installing a microcontroller onto my truck in a couple of months, since it takes a long time to perfect the details of it. I plan on setting up a wireless transmitter (blue tooth), being able to poll for trouble codes and transmit that to a PC. I was also planning on having it run an electric fan setup with pulse width modulation, remote start the vehicle, and disable the daytime running lamps unless i turn them on. the beauty of a microcontroller is that it operates at 5V and almost no current. If anyone else is interested, I will probably get cracking on this in another month or so.
Old 04-23-2004, 05:52 PM
therock's Avatar
Default Here is a tid bit
I have the 292 fans in transit.
I Wrote Flex-a-Lite about their VSC's bad reputation. After their reply I have decided to wait before going with the Delta VSC. One sign of trouble and I'll toss it for the Delta.
Allen.
Since the start of this style control, we have had concerns. We have constantly up-dated them to the point that there are very few problems. We have been standing behind our products for many years. The fuse holder issue has been solved with a different vendor. The terminal issue had been repaired with a different soldering process. The battery drain problem has also been addressed, this was a very rare problem. Please remember that we have a one year warranty and if you have a concern you contact me.
Thank you.
I wrote Delta about a VSC for the 292's. The 2 differences are, when the AC comp kicks in the Delta kicks the fans on @ 50% vs. the Flex-a's @ 60%, and the temp probes are reversed, the Delta is near the rad lower hose where the Flex-a's are at the upper hose of the rad.
From Delta:
Allen;
The FK-35 kit includes everything needed to replace the flex-a-lite vsc, including a 10 gauge wiring loom. I've enclosed the install sheet.
http://www.dccontrol.com/fk35.htm .
S / H is $7.00, priority mail.
Regards
Brian Baskin
Delta Current Control
408-379-8951
Old 04-23-2004, 06:09 PM
Hit Man X's Avatar
The kit came iwth 12awg though and is supposedly rated to 35 or 40A I think...
Should I change all my power wire to the batt to 10 awg? The fan wiring should be fine at 12awg as the fans draw about 12-14A each I think...
Quick Reply: Damned VSC
