DBW90mm/Carb Adapter
FormerVendor
Originally Posted by FarmTruc
Will it allow a 90MM aftermarket TB to bolt to it?
Originally Posted by Z06 DREAMING
Would this combo benefit a N/A application? If a custom CAI could be fabbed would it be comparable to a FAST 90/90 set-up?
Richard
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
FormerVendor
Thanks Grip! See what you started?????
I'm just trying to give guys some more options to get around the plastic truck intakes. I have no earthly idea if this will practically work, however on paper it should make a great setup especially for FI applications. I doubt it will fit under the hood of a car, but it was originally designed for trucks anyways.
Here's to ya friend
Richard
![EEK !!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_eek2.gif)
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
Here's to ya friend
![Chug! Chug! Chug!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_chug.gif)
Richard
I AM A MOTHERF*CKER
definitely, you have a PM ![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
Do it man. I can hook you up with a step by step up to the TB
Richard,
I was hoping you might share some insight on the quoted stuff below? I don't really understand it all.
Originally Posted by CHarris
Looks nice... I really like the o-ring seal, too. I had to hand cut a gasket for my TB because I bought my elbow before the machined option was available from Aaron ![Sad](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_sad.gif)
what do you expect the benefit to be from having less volume in the intake? Better (faster) throttle response? I didn't measure the volume on mine... but it has been said elsewhere on the forums that the following intakes have these plenum volumes:
LS1 5.06 L
LS6 5.19 L
Truck 4.00L
Edelbrock Vic Jr ?????
What do you think?
On my install, I haven't noted any softer pedal feel... but I have what is probably a fairly soft combo anyway... 402, AFR225's, 3000 stall yank, HEAVY *** truck, turbo cam, etc. I know that elbow adds a lot of plenum volume!
LS1 5.06 L
LS6 5.19 L
Truck 4.00L
What do you think?
what a rush!
Here's to ya friend
Richard![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
Here's to ya friend
Richard
![Cheers!!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cheers.gif)
