DBW90mm/Carb Adapter
#32
How do I change this text
Originally Posted by Z06 DREAMING
yeah, that would take some testing and custom fab work. Doesn't Speatech make a harness and conv. kit for cable to DBW? I thought I saw one a while back
#33
I knew if I bought the idle pulley relocation bracket for the car style intakes, something better would come out... just my luck...
Oh well, guess I had to take one for the team. Richard, how much for the adapters?
#34
Tin Foil Hat Wearin' Fool
Originally Posted by Wilde Racing
I'm going to check into that....Thanks.
Give Richard a call, he can hook you up with a barrel tb that bolts directly to the Vic Jr 4150 bolt pattern and it flows better than a 105mm tb
#35
FormerVendor
I'm trying to get some info from Edelbrock on their 4 barrel ttb PN#3878. They rate it at 1000cfm of airflow. It's cable operated and uses a GM Delphi IAC and TPS. This on a Victor Jr. is definitely the bomb for cable setups. It still needs to be proved out on a truck though.
So who's volunteering?
Richard
Richard
#36
9 Second Club
Richard
Richard
#37
Richard
Richard
#38
FormerVendor
Well $hit Im just waiting for you to get back to me on if the damn IAC is going to work
I did notice that the TPS for these ttb also use the GM Delphi setup.
This looks like it should work for a cable setup.
Richard
#39
what a rush!
Still haven't been able to reach the guy at Edelbrock. I'll leave more messages today.
Richard
Richard
#40
Originally Posted by moregrip
Richard, I'd like to see one of your adapter plates on something like this :
