dc sport long tube headers?
#53
I just got to thinking and what is the point to have a 3" collector if all you are going to do is reduce it to a 2.5" to run the exhaust? If they make a smooth transition with the 2.5" that is on them and just continue on to a 2.5" pipe wouldnt that be better then reducing them?
#54
what a rush!
#55
Resident Retard
#57
what a rush!
"The concept of a merge collector is similar to the theory behind a carburetor venturi, and in both cases, they work on the principle of building velocity through the venturi effect. Air passing through an hourglass-shaped venturi accelerates as it passes through the narrowest part of the venturi then slows down and expands as it emerges on the other side. This expansion creates a pressure drop, in effect siphoning air into the low-pressure side of the venturi and drawing more volume through the venturi. In a carburetor, velocity has the effect of increasing airflow and fuel atomization; in a header collector, the venturi effect improves exhaust velocity and scavenging. By the nature of the design of a multiple-tube header, there is a large change in area as the gasses from the primary tubes merge into the collector. This rapid reduction in area causes an equally rapid decrease in the velocity of the exhaust gas, which reduces the scavenging ability of the exhaust system. Merge collectors are designed to minimize this change in area at the transition from the primaries to the collector, which allows the gasses to maintain the greatest possible velocity."
#58
Resident Retard
I am not saying your wrong or right. I am simply stating what I have read and what I have seen. I agree that when you reduce tube diameter pressure will increase on the smaller side. I don't understand how reducing and then increasing again will increase exhaust velocity and scavenging. It seems to me it would slow it down again and cause a backup/restriction..... IMO if you are going to reduce the pipe size to increase velocity and scavenging then keep it at the same size until you add more airmas like a into a y-pipe.
I am not trying to get into a pissing contest, just a fun debate on what would be better and why. I am not expert by any means...
#59
Grippy, I'm with you on that. I was just looking at a way to copy the orig. design of the AEM setup and without cutting or welding (as some guys on here just don't have the means)
#60
Resident Retard
I was not bashing your idea or anything, sorry if I came across that way, I would just go with your orginal idea and get the bolt on connectors with the O2 sensor bungs. You might be able to get away with bolting the headers in and being about to reuse your stock Y-Pipe and just use some pipe clamps to attach it or get that Pacessetter y-pipe or jegs has a stock Y-pipe with no cats u could probably cut some off and use.
