dccontrol fan controller
Old 03-07-2007, 07:11 AM
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by thunder550
dccontrol.com
Thanks thunder
Originally Posted by Carlos
so with this there's no need for the nelson harness or PCM flash?
Or can it be used in conjunction with the PCM flash and harness?
Old 03-07-2007, 07:21 AM
Carlos's Avatar
can you give me a rundown of how you have everything setup?
Old 03-07-2007, 08:30 AM
High on diesel fumes
thunder550's Avatar
This takes the place of a fan harness and comes with it's own temperature probe, so it does not interface with the PCM at all.
Basically you have a wire that runs to the a/c trigger, a power wire to the battery, a ground, + and - to the fan plugs, and the temp probe.
Old 03-07-2007, 08:45 AM
Hunt&Fisherator
silver-mod-o's Avatar
looks like a slick setup... how much would one of those set someone back?
Old 03-07-2007, 08:51 AM
Carlos's Avatar
Gotcha, i saw the + and - wires coming off the DC Controller but wasn't sure what kind of connection the fans had...I thought it was a special connector, so the fan just takes the + and - from the controller?
Old 03-07-2007, 08:55 AM
thunder550's Avatar
Depends on the type of fans you have. I had a Nelson harness for my 05 e-fans and I just re-used the connectors from that.
Old 03-07-2007, 08:56 AM
thunder550's Avatar
I bought the 60 amp unit (FK60). Pricing is on their website.
Old 03-07-2007, 09:04 AM
Carlos's Avatar
Anybody know how the LS1 fans hook up? Is it just the two wires or are there a special harness it uses to connect?
Old 03-07-2007, 09:58 AM
thunder550's Avatar
I think they have their own connectors too.
Avalanche2002
11-30-2015 07:31 AM
CD82
10-23-2015 07:32 AM
Wrecker 426
09-30-2015 09:39 PM
old motorhead
09-29-2015 08:22 PM
Quick Reply: dccontrol fan controller
