Debating between cam, or converter
Alright I am looking for a cam to put into my 01 5.3 RCSB. I am about to order my headers, and then going to start looking for a cam. What would you all recommend. I have been looking at the TR220. Or would a 112/114 be good? I dont tow or anything like that, just want to be a decent amount faster.
Or should I get headers, and then buy a converter. And then later on buy a cam?
Thanks for the help in advance
PT's Slowest Truck
I like cams, but most bang for buck and highest et gains will come from the converter, but consider what cam you want when you order the converter. The TR220 that you referred to has more than proven itself in the 5.3, especially a "blue cajun" rcsb that went into the 12's with that cam and the appropriate tuning
Since you are looking at the TR220, get the converter installed before (or at the same time) you swap the cam. Don't plan on mixing that cam with a stock converter in a daily driver. Most will advise at least a 3K converter to take nice advantage of it (and maybe even up to 3.6K as you are in a lighter weight RCSB for a daily driver).
PT's Slowest Truck
Would i notice it if i got a converter until I went WOT? Sorry I am completely clueless about transmissions.. Would it still be just fine for daily driving?
PT's Slowest Truck
It all depends on how tight the converter is, which is affected by a couple of different factors, one of the most important being the converter's size. Something like Circle-D's re-tooled TB converter or a Yank TT3000 will react much like the factory converter under normal part throttle driving conditions, but flash to somewhere around it's advertised stall speed when you mash it. Now a smaller 9.5" converter, with different internals, may require more throttle angle to get moving. Best bet is to talk to the converter manufacturer that you chose and tell them what you want, and they'll let you know your options. I bought my converter from Circle-D and the customer service that I received from Chris was excellent, even months after the sale when I called back with questions, he was more than accommodating. I've heard nothing but good things about Yank also. Both Circle-D and Yank are site sponsors, only Cirlce-D doesn't have a link to the right. If you go to the GM Drivetrain and Suspension section and search "Circle-D", you will find links to their website, including a thread about their new website
