Decisions decisions....
Hell yea!! Would you recommend a different piston or will I need to upgrade? And anything else you recommend I up grade? I figured the stock crank would be strong enough, what about rocker arms? Pretty much what stock parts can I use? And I thank you in advance, I'm sorry it's my first build and I want to do it right lol
It kinda depends on how much you want to spend. Thes stock bottom ends have proven to be very strong. Several people on here are WELL over 500hp on boosted applications with stock bottom ends. I've never changed anything bottom end wise so I don't have any recommendations. Did you say the engine is completely appart? If so now would be a good time to upgrade anything but if the bottom end was together I'd inspect it visually and run it. Hopefully someone that has upgraded those things will chime in.
KBOBOZ71
06-18-2005 04:06 PM
