degreeing a cam with the heads off
Is it possible? I will be doing a heads cam swap shortly, this is my first venture into the motor, and have been reading about the degreeing vs. Dot to dot install theories. What I haven't seen is a writeup on the process of degreeing the cam with the heads off. Is that because its not possible, or because its so simple it doesn't need a writeup?
Everything I am reading is basically using the crank position and valvletrain to verify that the specs on the cam are what they are supposed to be, and to make sure the cam is right where it needs to be. My question is can't this be done using a dial indicator on the piston itself and then on the cam lobe, as opposed to a solid lifter or the valve spring retainer? Like I said, this is my first venture into the motor, do the heads need to be installed for some reason prior to degreeing?
Thanks.
Thanks.
It's much easier to do with the heads off. The hardest part is getting the dial indicator on the lifter, and keeping it solidly there, because it's WAY down there in the lifter bore. You'll need a dial indicator extension to reach it.
One word of caution, though. Don't buy any of the "Cam Degreeing Kits"...............They're for everything BUT the LS engines. Ask me how I know!!! A good magnetic base dial indicator with a 2" extension is needed. Comp Cams has a crank turning tool that you can use a degree wheel with, and it won't slide on you. Also, get the smaller degree wheel from Comp, too.
I plan on that, Inmotion single adjustable. I bought a Comp 11" wheel, and I figured I would turn the crank with a strap wrench and good intentions. I will check out the 'turning tool'.
Something tells me that you bought a kit and THEN figured that out?
Thanks for the info fellas.
GrooveCityZ71
08-31-2015 12:05 PM
