Denso 300LPH pump?
This link should help. It's meant for ricer boys but whatever its good tech
http://www.stealth316.com/2-fuelpumpguide.htm
I'm going to try the Weldon 1100-A pump when i go turbo, i think i've got a good idea about how to do the fuel system so it works like stock. i'll take plenty of pics of the installation so i can make a write-up if it works right
Denso is the best intank you can buy.The 044 is an inline pump that alot of guys put in the tank.
As far as flow ratings,I want to say the 044 is rated a 300lph as well but they flow alot lower than advertised.
Does that anwser your question?
bump, bc I am tired of searching for this to find the info.
I am looking at upgrading my fuel system to under 1000HP. My plan is a denson pump, with a hot wire kit or a boost a pump. my reading is saying if you give this pump good voltage it will out flow the rest.
anyone else looking at this? anyone have a good cheap fuel system upgrade?
I am making 62xrwhp and my bosch pump didn't show any signs of stopping. It was making 80psi of fp at wot at 6000rpm when my alternator started dropping voltage to 13v, and it still didn't drop pressure.
rednekferlife101
09-14-2015 06:27 PM
