Descreened MAF
Truck addict
i removed mine and i have noticed a problem with running lean. as far as power, i have never been on a dyno and probably never will. it is just something i did and i will live with it. eitherway, with as many people going to thunder shootout, i am more than willing to swap one for the other to do some track test. if it's even worth it.
13 Second Truck Club
Originally Posted by superchargedchevy02
I have said this many times in here all you have to do is put it on a dyno and prove to me that you gain anything other than potential problems by removing the screen. And don't give me any **** about seat of the pants feeling.
Hey I'm no expert and haven't claimed to be, this was coming straight from a GM powertrain engineer interview when the Z06 came out. I just remenbered it and posted up. Hell, if I remember right they also moved the cats closer to the manifolds and said that even helped with performance...Zed
![EEK !!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_eek2.gif)
Adkoonerstrator
Originally Posted by 99Silver5.3
This man has just revealed the answer!!!! Lean. Lean. Lean. A lean condition will sometimes make it feel like you had a slight increase in performance. Im no expert but take that screen out, log your truck with AutoTap and look at your LTRMs. Unless you are making ungodly HP number and flowing an ungodly amount of air you dont need to remove the screen. I took the screen out. And I paid for it. Now I have a shiny new MAF in my truck because over time with that screen gone my truck started to run like ***. No offense to anyone, but this question has been asked umteen times on here. Search button anyone????
Taking the screen out will reduce the reported load and also give more timing. More timing and less fuel for most people will cause knock. Not to mention that less reported load can cause the transmission to shift weird.
This mod is not worth enough hp to justify the downsides that can happen IMHO.
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
I do have the dyno to prove that theory wrong.
![The Judge](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_judge.gif)
Makes it lean my a$$.
And as far as the vette having a straiter intake tube than the truck making it ok to run with no screen is BS also. The shape of the intake tube has NO affect of how the MAF reads because the MAF is BEFORE the tube. It measures the air before it ever enters the tube.
![Engarde](https://www.performancetrucks.net/forums/images/smilies3/engarde.gif)
I have descreened EVERY one of the vehicles i've ever had with a MAF and did notice a slight increase in how they rev.
IMO descreening is a good free mod!!!!!!!!!!!!!!!! If your truck or car messed up when you did it you MUST have touched or broke one of the electrodes. YO BAD!!!!
