Descreening the MAF
im tryin to buy a house and dnt have money so free mods are great i punched out my screen cut a hole in front of stock air box and removed the rubber mat that blocks out side air next to the radiator havnt had ne probs a very slight increse in mid rage power and about 1.5 mpg increase
Moderately Differentiated
Sounds like your airbox gave you those bumps in power.
The screen is not a restriction. Unless someone can show a cfm comparison, I'll never believe it's a restriction. Just an air direction device. So if you are getting gains from removing your screen and don't have issues, then your particular setup (more than likely your CAI) is causing the air to move a certain path through your MAF to net you a leaner tune. In a stock scenario, lean can be good.Can be, not necessarily is.
Maybe a .002 cfm restriction. LOL
