Desktop Dyno 2000 file for 5.3...
I bought Virtual Engine 2000 ($40) and found it was a lot different than Dyno 2000... it is easier to enter the cam data, but now my 333 HP LM7 is only rated at 215 HP (SAE Standard) .
Thats pretty weird with the change in output power you are seeing supra... As far as converting regular cam data to what DD needs, I am just as lost as you. Jeff i get about the same as you with the MTI C2 profile i have... its pretty crazy..
Originally Posted by V8 Supra Builder
I've never figured out how to convert duration numbers @ .050 to Intake Valve Open (BTDC), IVC (ABDC) Exhaust Valve Open (BBDC) and EVC (ATDC). If someone can share a formula to do so, I can make a calculation form in another program that will do this the right way.
Thanks Tdrumm, I was afraid of that, I'm sure my educated guesses are off by a bit on DD2K.
I found that on Virtual Engine 2K by changing the exhaust from stock to "high flow single", the HP jumped to 324 @ 5000 & the TQ is 367 @ 3500. I still need to figure this program out, but it is easier to use for bench motor building since you don't have to guess at valve timing.
I found that Crane Cams has Gen III cam card info on their website, and entered a few as DD2K files. I zipped them & have attached the file.
I've run several combos w/ VE2K and am getting the hang of it, still a good bit of variation between the two for some reason.
b4z
09-10-2015 06:58 PM
creekrat
09-10-2015 12:59 AM
norris_83
09-09-2015 04:14 PM
