diablo users inside
Re: diablo users inside
Ditto from above! From what I've been told, you want +1.56% on your long term fuel trims and 0.00% at WOT. I played with mine to much at the start, started adjusting the spark and fuel trims after about 2 days, I put it all back to stock, loaded the performance program and just adjusted the tranny shift points, firmness, etc.. I'm going to give each change a full tank of gas to let the ECM have time to adjust fully. When I check my fuel trims, they pretty much fluctuate the whole time, it's hard to get a good reading while cruising. Any little change in speed or pedal position and the start to fluctuate. Make small adjusts and give the ECM time to adjust over time is my suggestion from my experiences so far.
Jim
Jim
Corvette454l88
09-01-2016 01:24 AM
JFortner5
08-20-2015 06:13 PM
signguy62
07-27-2015 03:42 PM
