did a cam swap quick question
Old 02-21-2010, 10:36 PM
PT's Slowest Truck
budhayes3's Avatar
Installing the cam itself will make the PCM think that there's a misfire due to the characteristics of the added overlap of an aftermarket cam. You need to soften up the misfire counter in the tune.
Old 02-27-2010, 06:51 AM
03 BLACKOUTSSS's Avatar
^^^ x2
Had the same issue after a cam swap, had Justin (Blackbear) adjust the misfire counter, problem solved.
Old 02-27-2010, 07:43 AM
OnyxSilveradoSS's Avatar
the two wires that connect to the cam sensor are easy to screw up if you are playing back there.
I agree about tuninng being the best fix
Old 02-27-2010, 07:44 AM
OHsixLS3
12-27-2016 09:30 AM
low2001gmc
07-23-2015 05:10 PM
WICK3DxGATA
07-21-2015 06:59 PM
Aboss
07-09-2015 10:28 AM
GreyChevy
07-07-2015 08:57 PM
Quick Reply: did a cam swap quick question
