Did a Compression Test...think I gotta problem..
just for ***** and giggles since my truck went from 382 to 317 on the dyno the other day i did a compression test on all the cylinders..the motor was warm and i unplugged the coil packs and open the throttle and crank it several revolutions like ive always done on my race cars...
#1 175 psi #2 150 psi
#3 164 psi #4 140 psi
#5 180 psi #6 170 psi
#7 155 psi #8 115 psi
do i smell a burnt piston?
That sucks man, If i were you i would just get some stock bore forged pistons and throw em in.
I figured thats what did it when you posted up in my ***** thread, I was gunna reply but BC padlocked it
and when the key was found i forgot all about it!
If it wasnt burning oil id say use it. Def. Check #8 to make sure the walls arent scared.
Id Mic. them all just to be safe.
If you change your oil on a reg. basis which im sure you do lol there shouldnt be much cyl. wear at all.
It would save you a couple hundred bucks and several hours.
If those walls are bad build a forged 370.
Matt put in some stock pistons with his engine still in the truck LOL.
