Did a Compression Test...think I gotta problem..
Old 02-10-2008 | 12:54 AM
CHEVRACER83's Avatar
well you got the nice new pro mod intake.... any word on if that helps the #7 = death problem??
Old 02-10-2008 | 10:15 AM
dirt track racer 81's Avatar
we'll find out when i build my new motor
Old 02-10-2008 | 06:49 PM
gmcdealertech's Avatar
Ive heard utilizing the steam ports on the back of the heads also helps #7, guess you have to trim a little intake to make the pipe fit?
Old 02-10-2008 | 07:37 PM
started on it around noon today..took awhile to get up..spent 63.50 at the bar last night just now got back from goin back and payin my tab...anyways got the piston pulled out and didnt find anything to question about..sprayed some stuff down the int and ext runners and never leaked..head gasket didnt look too bad..anyone got any other opinions
Old 02-10-2008 | 07:53 PM
Derek @ EDO's Avatar
FormerVendor
How do the valves on the heads look? What about the springs?
Old 02-10-2008 | 07:59 PM
i put some carb cleaner down the runners and they never leaked through..tomorrow ill pull them apart and look at the better
Old 02-10-2008 | 08:01 PM
FormerVendor
Did you remove your valve cover?
If the pistons look good its probably a valvetrain issue.
Old 02-10-2008 | 08:02 PM
i took the heads off..springs looked ok..
Old 02-10-2008 | 08:07 PM
Im seeing alot of 5.3's and 6.0's leaking around the valve seat. level the head as best possible, pour some solvent in the combustion chambers and squirt air through the runners. Some leakage is normal but you should be able to tell if it's excessive
Old 02-10-2008 | 08:11 PM
i did a valve job on this before i put these heads on..but it wouldnt surprise me..the heads are 241 5.7 ls1 heads
