Dirt in heads
Old 02-08-2008, 08:26 PM
PT's Slowest Truck
budhayes3's Avatar
Man, that's rough...I wouldn't be surprised if it still had the original factory oil filter on it. As for the intake ports, looks like alot of carbon from a combination of normal operation and oil being sucked in through the PCV system. I doubt that your friend ever put a can of Techron or something like it in the gas tank.
FWIW, here's what it looked like under my driver's side valve cover around 40k-ish:
Old 02-08-2008, 09:20 PM
Wearin' da big hat
00ChevyScott's Avatar
does seafoam burn all that **** out?
Old 02-08-2008, 10:55 PM
rpav's Avatar
holy fvck!!
Old 02-08-2008, 11:00 PM
PT's Slowest Truck
budhayes3's Avatar
It's supposed to clean the intake ports and combustion chambers...it may not get all of it but I'm sure it helps if done correctly. I've done BG pressurized induction services and looked at the before and after results with a boroscope and it's gotten the combustion chambers and valves almost spotless. I'd imagine that the results from Seafoam would be pretty similar...maybe one of these days I can borrow the boroscope from work and check it out.
Old 02-09-2008, 12:41 AM
Justin_inc's Avatar
want to see what an engine looks like with 200,000km's and 1 oil change? (i'm sure it had to be only one, i was pulling solid sludge chunks out 2X2" in diameter from the valley from this engine)
lets say it came out to be rebuilt!
Old 02-09-2008, 01:13 AM
Holy **** looks like something out of a horror movie.
Old 02-09-2008, 06:48 AM
HorsePower Hunter's Avatar
mmmmmm...Did you buy that from the same guy I bought mine from??
Old 02-09-2008, 07:40 AM
03 BLACKOUTSSS's Avatar
10:1 says that engine has been underwater
Old 02-09-2008, 09:00 AM
Wearin' da big hat
I was JUST thinking that. Pull up the carpet and check the interior for signs of flooding. I'd get the VIN checked out too for shop/insurrance claims
Old 02-09-2008, 09:05 AM
xlcooplx's Avatar
my buddy's 4.8 with 225k miles didnt look nearly as bad as that...
Quick Reply: Dirt in heads
