Do I Need To Degree my Cam?
Old 12-01-2006, 01:28 PM
jakebdb56's Avatar
I wouldn't even worry about it.. The stock T chain will work fine..
the stock timing chains will hold up to a lot of power. hardened steel gears are some bad ****'s.
Old 12-01-2006, 03:45 PM
Yogi Bear's Avatar
Here's a good comparison between a stock chain and an LS2
Looks like a lot of difference to me.
Old 12-01-2006, 04:36 PM
jakebdb56's Avatar
really the big difference is going to be in the grade of the steel. the thickness is the same throughout, as it appears to be. they look to be basically the same exact design, just the ls2 might be a weee bit beefier. steel specs would be good hard baseline data though
jake
Old 12-01-2006, 05:47 PM
TURBHOE's Avatar
after like 2004 all the 6.0l got the same timming chain. and are a direct replacement for all the othe lsx engs. if you 6.0 is before this time then yeah the ls2 one is bigger.
pittman
01-19-2016 07:06 AM
Three6GMC
11-05-2015 10:02 PM
Tig
09-30-2015 07:39 PM
Jake99
08-08-2015 07:56 AM
MWRitter
07-27-2015 09:41 AM
Quick Reply: Do I Need To Degree my Cam?
