Do I Need To Degree my Cam?
I wouldn't even worry about it.. The stock T chain will work fine..
the stock timing chains will hold up to a lot of power. hardened steel gears are some bad ****'s.
really the big difference is going to be in the grade of the steel. the thickness is the same throughout, as it appears to be. they look to be basically the same exact design, just the ls2 might be a weee bit beefier. steel specs would be good hard baseline data though
jake
jake
