Doctor, Doctor, give me the news!
what does this sounds like ?
bent push rod , lifter fail ? or did I spin a bearing ? I have been driving with this sound for 500 miles + no problems but the sound
I have a bad idle tunning it doesnt do this all the time
no it doesnt at all drives the same in every aspect even shifting at 6800rpms in second and reving to 6400 in 3rd and pulling in forth to 140mph and the truck has the same power befor the ticking sounds
the story goes like this : started to play with the tune , added some advance on the spark after we got the AFR where we want it , a spark plug broke its tip , checked all spark plugs, only number 1 was bad, every plug else was ok , changed them any way
did a compression test all pistons read 110-120psi constant, no fast presure drop in all cyl's, all have the same rate
started the motor , the sound never changed sence the sound came out a 9 days ago
