Doctor, Doctor, give me the news!
Old 10-22-2012 | 06:37 PM
  #41
Lucille's Avatar
Tend to agree with AK. When you said shifting at 6800 and noise behind the timing cover I assumed you had the spring tensioner and it had failed. Since you've got the wedge- Keep Digging.
Any abnormal wear on the cam lobes?
  #42
sand man's Avatar
will , I ll drop the oil pan tomorow and see what happens
Old 10-22-2012 | 06:38 PM
  #43
sand man's Avatar
no , all cam lubes look ok to me
Old 10-22-2012 | 06:41 PM
  #44
Lucille's Avatar
Still on stock pistons?
Old 10-22-2012 | 06:44 PM
  #45
AKlowriderZ71's Avatar
11 Second Hall Moniter
You need to be looking at the piston to cylinder wall clearances if you don't have a broken ring land.
Old 10-22-2012 | 06:51 PM
  #46
Lucille's Avatar
Ditto. You say the pistons were fine , but I'm betting when you pull them out of the cylinder one of the ringlands is broken. Ask me how I know
Old 10-22-2012 | 07:13 PM
  #47
sand man's Avatar
yes stock pistons .
ill pop piston #1 and see what in there
Old 10-22-2012 | 07:56 PM
  #48
TDFDiesel's Avatar
Hope you find the issue, curious to see what you find.
Old 10-23-2012 | 01:33 PM
  #49
99 2500's Avatar
Didn't see if you said anything about checking the valve springs. I had a inner spring break on a dual spring and it also made a similar noise, and I didn't find it until after I pulled the heads --- what a waste that was.
Old 10-31-2012 | 01:36 AM
  #50
sand man's Avatar
so Im in the market for a 408 rotating assembly with 9.5:1CR any one have anny advice
