Does removing the right headlight really make a difference?
Old 04-12-2005, 08:55 AM
slowec's Avatar
Originally Posted by thunder550
Ill try it too then next time...all of you running CAI or stock airbox?
Time to bring out the one-eyed monster
k&n gen 2 , dont help at all until the light is removed.
Old 04-12-2005, 09:00 AM
Green Thunder's Avatar
It does work..
Old 04-12-2005, 09:06 AM
BigKID's Avatar
Like others have mentioned, it only works if you have some sort of cai with an open element behind the headlight opening. It will do nothing for a stock box or other enclosed aftermarket intake. FWIW.. I take mine out evertime I go to the track.
Old 04-12-2005, 09:48 AM
TigerFan187's Avatar
I take mine out usually and sometimes take the filter off as well! I know on the dyno when i took the filter off I picked up 2 rwhp!
Old 04-12-2005, 12:29 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
The air filter straightens out the air and if you take it off it can cause turbulence in the maf and you can loose power IMO its better to keep it on. I take off my headlight too and it does help although I only gained a tenth with it.
Old 04-12-2005, 02:10 PM
GoldenVelvet's Avatar
Ya know when you yank the head light out you can see the filter through the hole. How could that not help. But, I never realized how often people do ask. Im going to tell them its to lighten the passenger side so the wheelie is even. lol
Old 04-12-2005, 02:44 PM
High on diesel fumes
thunder550's Avatar
some people will prolly take you seriously and walk away thinking you're nuts. poor them.
Old 04-12-2005, 03:07 PM
Truck addict
goshawk23's Avatar
i take mine out. like mentioned above, it takes only a few seconds to remove and if it helps bring cooler air in through the front of the engine vice from the engine bay then to me it's worth it.
Old 04-12-2005, 05:47 PM
13 Second Truck Club
1BADDASSBOWTIE's Avatar
It is possible to make it work with the stock airbox. You have to pull the box out, loosen the clamp on the lid, and twist the lid towards the light. I went from 14.29 to 14.17......so I think it works.
Old 04-12-2005, 08:13 PM
Dark Halo's Avatar
I take my head light out and remove the bottom of the box and the filter. I then slant the top of the box so it acts as an air catch and forces the air into my custom made intake tube.
Quick Reply: Does removing the right headlight really make a difference?
