Drive By Wire conversion.
Ok guys, as many of you know, I am getting ready for a V6 to V8 swap.
How hard would it be to convert my 2005 V6 to DBW for the swap. To be honest with you, I haven't even looked to see if it is cable. I am pretty certin that it is. Would it be worth it to convert it, or should I just get a cable TB.
I also purchesed a fairly large cam (.639 lift intake) should I think about a 90MM TB or would a stock one work fine.
I think the easiest thing to do would be to go with a cable if that is what the v6 is setup for. Otherwise you will have to get a new peddle and all the wiring to hook it up.
I can't answer about the intake, but damn what cam did you buy?
This is the link to the cam that I bought https://www.performancetrucks.net/fo...d.php?t=398442. And that is kind what I thought about the TB.
I think you will be fine with the stock TB. I don't think you really need the 90mm until you start getting into more cubes and better flowing heads.
On another note... What springs are you planning on running??
I think that is too much lift for the comp 918's so I think you are gonna need some dual springs to run that much lift.
The patriot gold's are dual springs and I think a lot of people use them. I would say no on the LQ9 springs being good for that much lift.
As far as the LQ9 intake. I am thinking all the truck intakes are all the same not including the SSR intake.
Sorry man, but buying that cam was stupid. You are going to get NOTHING more than problems running a cam with that high of a lift. You're gonna be on stock heads right? Even on stock 317s, they max out well before .600(around .560 to be more exact). So basically you're just gonna go through valve springs for no reason.
Now if you had some milled 317's worked to flow a bit better then that cam might be worth it.
Oh and the lq9 intake is the same as the 4.8L/5.3L intake.
Oh and you'll be fine with teh 78mm throttle body because your heads won't flow well enough to justify stepping up to a 90mm tb.
