Drive By Wire conversion.
I would have to agree on the cam... It's really overkill for stock heads. You might be better off selling it and finding something more on the order of a tr224, vinci trucker cam or similar. Something with under .600 of lift.
EDIT-The stock 5.3L heads begin to max out at .500 lift(that's not a typo) and even if you get new heads, the intake maxes out at about .600 lift. Both don't flow very well, but the stock 753(or whatever they're called) heads are ****.
Originally Posted by usarmyman
The heads are stage1, I don't think they are stock, could be wrong.
you will need a complete wiring harness for a 5.3..cut the injectors leads off and put on some bosch leads from the parts store..28 lbs ls1 injectors should work..you for the year model you are your probably returnless fuel system so you can make ls1 fuel rails work..for that cam id run a fast 90/90 intake and tb..wich is cable drivin..this gonna be a 6.0 or 5.3??
